FeatureReader Search Envelope
  • Nov 21, 2016 6:05 AM UTC
  • 6 replies
  • 394 views
brady
Any particular reason why I cannot find search envelope parameters for the FeatureReader when pulling in a WFS stream? Any assistance would be helpful :)
Thanks.
  • Nov 21, 2016 8:21 AM UTC
The FeatureReader uses the Initiator geometry as the search envelope.
You can easily create a search envelope box to pass to the FeatureReader with e.g. the 2DBoxReplacer.
You can then set the Spatial Filter setting in the FeatureReader to e.g. "Envelope Intersects"
itay
Forum|alt.badge.img+19
  • Nov 21, 2016 10:07 AM UTC
erik_jan
Forum|alt.badge.img+26
  • Nov 21, 2016 7:47 PM UTC
The Creator transformer can be the initiator for the FeatureReader.
Use the Box geometry and set the Min and Max values.
brady
  • Nov 22, 2016 12:37 AM UTC
Thanks for the suggestions @erik_jan, @itay, and @david_r. I will try these out.
I need to run a process before the feature reader and I already have numerous workspace runners. I was trying to avoid nesting workbenches more than two deep.
I have been trying to use @Mark2AtSafe's suggestion to piggyback the bounding box parameters on the wfs url like below but that isn't working for me yet.
https://geo.onroerenderfgoed.be/geoserver/vioe_geoportaal/wfs?request=GetFeature&version;=1.1.0&resultType;=hits&typeName;=beschermde_archeologische_zones&srsName;=EPSG:99999&bbox;=12345,12345,12345,12345
gio
Forum|alt.badge.img+15
  • Dec 1, 2016 5:06 PM UTC
I would rather create the box then use a workspace runner to pass the extent to the url. Not use a feature reader at all for that.
Rather then reading the entire wfs and then selecting some extent...some can be very big.
itay
  • Dec 1, 2016 7:08 PM UTC
When using a FeatureReader on a WFS it will actually query the service for the data inside (if that is how you set the spatial interaction) the creator geometry, so its actually much more efficient reading and not at all reading the all service and then filtering....
Querying the service with the resultType=hits is asking the service something like: "hey! how many features are you going to return for this area (bounding box)?" which is especially handy when services have a limitation for the number of features returned per request.
