Fanout by fme_feature_type but remove irrelevant columns in each excel sheet
  • Apr 26, 2018 6:01 PM UTC
  • 111 views
I have a problem with writing the multiple sheet output to excel but keeping only the attributes that are relevant to each sheet. For example (as you will see on the image) SAC_NAME should only be in the sheet named Special Areas of Conservation and should not be present in the sheet Wood Pasture and Parkland... and vice versa the PRIHABTXT attribute should not appear in the sheet Special Areas of Conservation... What I get now are columns of empty attributes.
I tried to use PythonCaller to remove the empty attributes but it did not work, since the writing actually happens in the writer and PythingCaller is before the fan-out happens (I imagine that before fanout all is in one sheet and none of the columns is entirely empty).
  • Apr 26, 2018 10:23 PM UTC
Hi @sylwianikel, the fanout just separates features to different destination feature types (worksheets) depending on the feature type name, it doesn't configure destination schema (user attributes) automatically.
If you will configure the destination schema statically as you did, you have to add multiple writer feature types for each schema and route features to an appropriate writer feature type according to their feature type name.
Or, if you want to use just a single writer feature type and configure destination schema dynamically depending on feature type name, consider setting "Dynamic Schema Definition" and additional common user attribute (_distance).
  • May 26, 2018 11:51 AM UTC
Hi @takashi, Thank you for your reply and I'm sorry I replied so late. I'll try your solutions and see what I can do.
