Best Answer
Failure of the XLSX writer when exporting
  • August 8, 2017
  • 6 replies
  • 106 views
arthy
Forum|alt.badge.img+8
I'm trying to export my data to excel. My workbench was working fine and suddenly I can't even run it.
I'm having the following error and I don't know what could be the issue.
I restart my computer and I close all the excel files on my computer but the issue persists.
XLSX Writer: Saving changes to dataset 'folder_name'
XLSX Writer: Failed to save changes to the spreadsheet 'folder_name'. Check that you have write permission to the file, it has no password protection and is not opened by another application. Error message is 'Permission denied.'
A fatal error has occurred. Check the logfile above for details
... Last line repeated 2 times ...
Note that folder_name is the localisation path where I want to export the data.
Thanks
Best answer by courtney_m
Okay, thanks. The error message says it is trying to write a spreadsheet called 'folder_name' - make sure your output excel file path points to a file and not a directory. Would you be willing to upload your workspace, please, so I can get more information?
courtney_m
Forum|alt.badge.img+22
  • August 8, 2017
In Windows Explorer, right-click on the folder you are trying to write to, and select properties. Is "Read-only" checked?
arthy
  • August 8, 2017
I I checked that under security and I have the rigth to read and write in the folder.
Before the excel writer, I even added a python caller and inside the python, I try to copy a file to that folder and it worked
courtney_m
  • August 8, 2017
courtney_m
  • August 8, 2017
arthy
  • August 8, 2017
You are right.
I scripted the folder name and there was a misspelling.
Thanks again for your help.
I really appreciate
courtney_m
  • August 8, 2017
You are right.
I really appreciate
You're welcome. I'm glad that worked!
