Failed to add feature type Relationship Class when adding a writer
  • Jul 10, 2019 9:20 PM UTC
  • 76 views
I am having an issue adding a writer from ArcSDE. I am looking to write to Relationship within Oracle SDE, it is 1-many. On creating the Writer I get the following,
The table name 'SMU_SPATIAL.Report_PhotoRepeat' could not be found in the Geodatabase as either a feature class or a table. This may be because the current user does not have permission to see 'SMU_SPATIAL.Report_PhotoRepeat'
However when I add the Writer I am using exactly that user SMU_SPATIAL. Has anyone ran into this, any help would be appreciated.
Thank you
nampreetatsafe
Forum|alt.badge.img+14
Hi @jeffjamesjudyck, do you see SMU_SPATIAL.Report_PhotoRepeat in ArcCatalog using the same user?
Yes, I sure do @nampreet
