Extract XML data from an Access Database table
  • Mar 8, 2019 4:00 PM UTC
  • 95 views
In MS Access database, the Occurrence table has an XML data type field called “ReportDataXML”. This field contains details/values for all the fields on a particular form for a given record.
I need this field transposed to a table for each record in the Occurrence table. The transposed table should have columns for record id and the xml values for each node – see second table for an example of what I’m after.
Source data sample – record id = 6, ReportDataXML field extract only for 3 fields.
Occurrence table ID field has value:
6
ReportDataXml field has the following content (exerpt only):
<F7183047af02945f1aa4cf819519c1b72 xmlns="http://www.gaelquality.com/Bacchus/OccurrenceFields" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<DataType>list-reference</DataType>
<Value>3193</Value>
<Archived>false</Archived>
</F7183047af02945f1aa4cf819519c1b72>
<Fa080141ebf5b417999a0b5da90569306 xmlns="http://www.gaelquality.com/Bacchus/OccurrenceFields" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<DataType>string</DataType>
<Value>Garry Capp</Value>
</Fa080141ebf5b417999a0b5da90569306>
<F824a8279f81a4eeaba0e3b6ac62bbccd xmlns="http://www.gaelquality.com/Bacchus/OccurrenceFields" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Value>The employee, received an injury to their shoulder and neck whilst using a crowbar to remove rocks &amp; concrete.
INC allocated to wrong work area. Found INC report and attached relevant docs that actions had been completed. S Gueth</Value>
</F824a8279f81a4eeaba0e3b6ac62bbccd>
Expected output from transpose would be:
ID
UIElement
DataType
Value
Archived
6
list-reference
3193
FALSE
6
string
Garry Capp
FALSE
6
string
FALSE
Could you please guide me with the steps please?
friesewoudloper
Participant
If I understand you correctly, I think an XMLFragmenter should do the trick. Your XML example files are incomplete, so I'm not sure. I've added a screenshot as an example. You should replace `RootNode` with the name of the root node in your XML files. I am assuming the UIElement nodes are direct child nodes of the root node, and that there are no child nodes other that UIElement nodes.
friesewoudloper
Participant
So the contents of ReportDataXML are actually not well-formed XML? That is kind of weird.
You have to make some changes to the contents of ReportDataXML to create an XML document that *is* well-formed. You can use an AttributeCreator and some StringReplacer's to achieve this.
I created an example workspace for you: https://gist.github.com/FrieseWoudloper/e411c25d669760ebcd37e5175e638fa1
You can download the ZIP file containing the workspace: https://gist.github.com/FrieseWoudloper/e411c25d669760ebcd37e5175e638fa1/archive/da4d1e070c53ca5959cf1895a2280dcfc7c7e00c.zip
  • Mar 11, 2019 11:51 PM UTC
Thanks very much for your help - excellent!
Solved my actual requirement and learned a lot in this process - appreciate your effort and help.
