extract spatial info from XML (ISO19115) to build up feature
Hi
I've a lot of xml files ISO191115  (like the one at the link below)    with some spatial info as the EX_BoundingPolygon that I need to extract for build up some feature in kml or shape format.
Do you have any idea or suggestions?
TIA
ciao
fz
link to example file:
https://api.echo.nasa.gov/catalog-rest/echo_catalog/granules/G26813121-LPDAAC_ECS.iso19115_2?token=3F8812EE-8A4F-EAFF-FE95-E6A036ACC3C1
Best answer by fmelizard
The geometry replacer (GML encoding) can be placed directly after the reader, and as Takashi mentioned the xml_fragment attribute should be use to convert the geometry.
fmelizard
Forum|alt.badge.img+19
  • September 1, 2013
You can read the XML and use the geometryreplacer to convert the geometry into spatial features.
  • September 2, 2013
thank.
I've setup an XML reader, configurated to match  EX_BoundingPolygon, Feature_Paths and flattening enabled. So this return me among the user attribut  the polygon line string.
(something like ...<gml:posList>46.211 12.5684 46.0997 13.357 45.5501 13.1555 45.6603 12.3745</gml:posList>...).
As you suggest I put down the reader a geometryreplacer trans, but I amid the river flow now.... infact I guess the right geometry encoding I need to choice (GeoRSS? GML?), and again I need something between  reader and transformer?
TIA
ciao
fz
  • September 2, 2013
The GeometryReplacer (GML Encoding) assumes the source attribute is an XML fragment containing a GML element. If you flatten EX_BoundingPolygon element with the XML reader, try specify "xml_flagment" to "Source Geometry Attribute" of the GeometryReplacer.
Takashi
fmelizard
  • September 2, 2013
  • September 2, 2013
Hi
great!!  Now it's more clear. Thank.
A last question: feeding  xml_fragment to geometry_replacer produce (of course) a line and not a polygon. Do you have idea how get polygon instead?
again thank
fz
  • September 2, 2013
The coordinate list of the data is not closed (the last coordinate is not equal to the first coordinate), so the GeometryReplacer cannot produce a polygon. But don't worry. You can close the line using the LineCloser transformer :-)
Takashi
