Extract Polygon information
  • Jan 12, 2025 3:26 PM UTC
  • 6 replies
  • 148 views
boubcher
Forum|alt.badge.img+11
Hello Guys
I have a polygon  we need to know the length of each segment and which direction the segment is facing
north , south , East or Ouest.
Thanks
danilo_fme
Forum|alt.badge.img+58
  • Jan 12, 2025 5:56 PM UTC
Hi ​@boubcher , how are you?
Could you share the polygons for us?
Thanks in Advance,
Danilo
  • Jan 13, 2025 8:19 AM UTC
You can use the Chopper (max vertices = 2) to divide the polygon into segments, then use the HorizontalAngleCalculator to get their individual orientation, and the LengthCalculator to get their length.
s.jager
Forum|alt.badge.img+27
  • Jan 13, 2025 12:06 PM UTC
Use the GeometryCoercer first to ensure the polygons become lines, otherwise you’ll end up with smaller polygons.
Also be careful with the coordinate system in use: If that is not a projected one (ie you have lat/lon instead of x/y), the angle- and length calculations will be incorrect.
The PolylineAnalyzer might be the most elegant solution.
  • Jan 13, 2025 12:50 PM UTC
That isn’t necessary, the output from the Chopper will only contain lines if max vertices = 2.
True, you can also use the GeographicLengthCalculator if that is an issue.
I wasn’t aware of that one, looks interesting. It seems to have the same issue as the LengthCalculator regarding ground units, however?
boubcher
  • Jan 13, 2025 1:24 PM UTC
​@david_r
could  you please explain how  output of the angle and the azimuth from the Angle calculator will give me the orientation  , Est ,West ,North and South
Thanks
  • Jan 13, 2025 1:30 PM UTC
​@david_r
Thanks
The azimuth values increase clockwise from the reference point of north (which represents zero degrees). So you could e.g. say that _azimuth values in the range 315-45 = North, 45-135 = East, etc.
Example:
Source: https://academic.brooklyn.cuny.edu/geology/leveson/core/linksa/comp.html
