Extract info from WEBsite
checcosisani
Forum|alt.badge.img+12
Hi
I need to extract info from XML
I used the HTPP caller but now I need to extract the string related to tag <tbody> (see picture)
and I don't know how can procede
thx
Francesco
Forum|alt.badge.img+50
You can try the StringSearcher with a regex, I think <tbody>.+</tbody> should do the trick.
  • April 16, 2019
Alternatively the HTMLExtractor could also be helpful.
checcosisani
  • April 16, 2019
Hi takashi
thx this is the workflow that I would like to learn/follow but now I have this document
and I need to extract all the values between <span>..............</span>
thx
test.txt
Francesco
