exporting data into an excel template
  • Oct 23, 2017 5:56 PM UTC
  • 114 views
gboquin
Forum|alt.badge.img+8
I am trying to export sql data into an excel report template. for example: I need to pass a particular attribute to the cell A24. Any pointers?
Thanks so much
danilo_fme
Forum|alt.badge.img+58
  • Oct 24, 2017 4:34 PM UTC
Hi @gerry,
About to write attribute in a particular cell in XLS file, has two interesting Questions:
Thanks,
Danilo
andreaatsafe
Forum|alt.badge.img+17
Hi @gerry,
In the Excel Feature Type Writer, you can define the starting cell location using the following parameters.
Depending on your data and your excel template, you may or may not want to output the field names.
If you need more assistance, this article here has a section on starting cell locations (Step 8).
