Export linkage data from DGN
  • Mar 29, 2018 5:25 PM UTC
  • 160 views
Hello,
I have a DGN file (Microstation v8) which stores spatial data elements (elements with XY coordinates). The elements are linked to an external database. I need to export the data from DGN file and join the exported data with its associated data in external database. I am using FME workbench with reader format as "Bentley MicroStation Design (V8)" and writer format as GeoJSON.
When I redirect my output to FME data inspector, I see the linkage data in a field called "igds_linkage{0}.blob (encoded: fme-binary)". Sample value for this field is E06E00000000000000000000. The actual link value in the external database for this element is 28384 which is 6EE0 in Hex. I can get the same value by swapping the first two bytes of igds_linkage data i.e. from E06E to 6EE0.
Now, my issue is that this data is visible in data inspector only. How do I export it into my output GeoJSON file?
The field "igds_linkage{0}.blob" is a Format attribute of type char(255). I've checked the exposed checbox for this field into Reader Feature Type property window and mapped to a field in writer. But, I cannot get this data into my output file.
Can someone please help what I am missing?
Thanks in advance for your help.
Amar
fmelizard
Forum|alt.badge.img+22
  • Apr 4, 2018 10:07 PM UTC
Hi @amargupta,
Sorry for the delay in getting to your question - I've tried to do something similar here. I used an AttributeFileReader to read in a file an a binary HEX string. I also called it igds_linkage{0}.blob and the output GeoJSON seemed ok with it (was in my output file). I also renamed the output attribute and didn't have any issue. I was running FME 2018.
Are you able to do something similar? If so then perhaps there is something that needs to be configured slightly different. Perhaps you can share a small example where you are having the problem?
