Export dgn 7 to dgn 8 from attribute selection
  • June 13, 2017
  • 109 views
We want to export a DGN V7 file to v8 version with some specifications. For example: In version 7 we have grouped some elements in the same level, but with different colors and styles. The objective would be to be able to make different selections of level, style and color and in the reader environment, and export that selection to a specific level in the output file v8. How can we do this? thanks for your help
  • June 13, 2017
@emili - you can use the tester to parse that out. If you have V8, you can also use the internal batch converter there which is pretty robust and will do exactly what you are asking.
http://www.mdlapps.com/microstation/ustnhelp1054.html
  • June 14, 2017
Thanks for your help!!!!!!
