Excel writer problem when writing data that has multiple lines
  • Jan 29, 2018 10:07 AM UTC
  • 6 replies
  • 208 views
sebastianolaf
I have oracle table that needs to be exported to excel
the table has 1 column that has multiple line
Excel Writer is good enough to make it into 1 line automatically.
But the 2 words that separated by New Line or Carriage Return became 1 word instead split it with single space.
For Example an address Column:
"Hello
World"
Excel Write put it in 1 cell "HelloWorld"
no space between
"Hello" and World"
How to tell Excel Writer not to do that ?
Expected Result "Hello World" with space in the middle
Best answer by takashi
Hi @sebastianolaf, if it's allowed to replace carriage return and/or new line with a single space, it would also be a workaround to use the StringReplacer with this setting. The regex '\\s+' matches one or more consecutive white-space characters including carriage return and new line.
  • Mode : Replace Regular Expression
  • Text to Replace: \\s+
  • Replace Text: <enter a space>
  • Jan 29, 2018 10:26 AM UTC
In the folumn formatting dialog, make sure you set the Text Control to "Wrap text":
sebastianolaf
Hi @david_r
I tried, it still the same.
  • Jan 29, 2018 10:51 AM UTC
Weird, works for me.
What happens if you open the output in Excel, select the column and hit the Wrap Text format button?
My impression is that the newlines are indeed written by FME, and that it's a formatting issue in Excel.
  • Jan 29, 2018 11:06 AM UTC
sebastianolaf
Hm, I tried ran several times
It works after couple of try, I don't stand it either,
the 1st screenshot didn't refresh the excel, 2nd then ok
I didn't change the edit settings
Thank you
sebastianolaf
I also tried this way,
it works but i use '(\\n+)'
Thank you
