Excel Writer output name dynamic define
  • Mar 6, 2017 4:59 PM UTC
  • 220 views
Hello, is it possible to write date to Excel dynamically (as it happends with Shape-file)? Without writing the Name of the output at the begin? I wonder if there is any Workaround to do it?
In my case i Need to write Information in different Excel-Files with the Name of variable (depends on class of the data).
jdh
Forum|alt.badge.img+41
  • Mar 6, 2017 5:15 PM UTC
You can dynamically create excel files. It is not quite the same as with shapefiles as they are a folder based format whereas excel is a file based format. See https://knowledge.safe.com/articles/565/fanout-1.html
What you need to do is create a dataset fanout on your writer, not your feature type.
jdh
  • Mar 31, 2017 2:41 PM UTC
Thank you jdh!
