Excel to tab
  • Aug 5, 2013 2:26 AM UTC
  • 6 replies
  • 87 views
Hi all,
        new to FME and would like to know:
I have an excel sheet with a column of (Attribute id's) and a column of (lengths m).
I also have a tab file that relates to the excel sheet and has the same Attribute id's.
Can I change the spatial length of the polylines in the tab file to be the same as the lengths in the excel sheet??
  • Aug 5, 2013 6:35 AM UTC
If you need to replace the attribute value (i.e. length) of features in the tab file with the length value stored in the Excel worksheet,  the FeatureMerger transformer can be used.
Be aware that the FeatureMerger does not overwrite same named attribute, so you should remove the length attribute from the features before merging attributes. To remove attributes, consider using the AttributeRemover transformer.
Takashi
  • Aug 5, 2013 6:42 AM UTC
Thanks for the reply, however I have a new problem.
The poly lines I have in my tab file are not the same length that the attribute field displays, ie; if the attribute (length m) in the tab file says 100m, for example the actual length of the polyline for that particular feature may be 110m.  How do I make the polyline redraw as per the length stated in the attribute?
Torro
  • Aug 5, 2013 7:10 AM UTC
Hi Torro,
You mean modifying the line geometry based on the length attribute value? If so, the Snipper (Snipping Mode = Distance (Value)) can be used to shorten and the Extender can be used to extend a line. And also the LengthCalculator probably should be used to get the lenge of a line geometry. If the coordinate value unit of the geometry data is not meter, you should change the coordinate system before those handling. To do reprojection, consider using the Reprojector transformer.
Takashi
  • Aug 6, 2013 1:13 AM UTC
Thanks Takashi,
yes thats right im trying to modifying the line geometry based on the length attribute value.
Still having a problem, what do I put in the 'snipper' fields starting Location and Ending locations?
Torro
  • Aug 6, 2013 3:35 AM UTC
Also can I use the snipper and the extender transformers in the same workbench.  The Extender transformer just seems to undo everything the snipper did??
  • Aug 6, 2013 6:21 AM UTC
Hi Torro,
Yes, you can use those transformers in the same workspace. Assume every line feature has an attribute named "attr_len" (indicating length value), this workflow performs snipping or extending at both end of the line based on the difference between "attr_len" and calculated length, for example:
Takashi
