Excel template file doesn't work after FME update
  • May 2, 2019 3:09 PM UTC
  • 5 replies
  • 100 views
I have updated my FME Desktop 2018.1 to FME 2019.0 and my workflow writing excel files based on a template file stop working. I was able to go around missing conditional formatting with few ExcelStylers. However, I am still missing the print layout which I have defined in the template. All required formatting stays in the template sheet, but is not distributed to the sheets written by FME. What have 2019 version changed and how can I use my template file again?
Best answer by rahulsharma
HI @jakub, we believe the is indeed a regression issue that we is currently under development. I can notify you once we have resolved the issue If you still like to send us your data and workflow via a support ticket (https://www.safe.com/support/report-a-problem/) and we can notify you on updates on the progress via ticket.
Workaround: Unfortunately, we do not have a workaround, you can continue using FME Desktop 2018.1. You can have multiple FME Desktop installed on the same machine.
Update: The issue is resolved in FME Desktop 2019.2 and 2020.0
rahulsharma
Forum|alt.badge.img+12
  • May 3, 2019 10:21 PM UTC
  • May 6, 2019 8:31 AM UTC
Thanks @rahulsharma for the information. I will make a support ticket to be notified when this is fixed. In the meantime I have reinstalled the old version.
ksu_geographer
Participant
Has this issue been resolved in a new release of 2019 yet?
  • Sep 2, 2019 11:16 AM UTC
Unfortunately still hasn't been solved in 2019.1
  • Nov 14, 2019 9:32 AM UTC
2019.2 has fixed this issue.
