Excel: read schema via user parameter
  • Sep 16, 2019 10:46 PM UTC
  • 7 replies
  • 121 views
I need to read an Excel spreadsheet. I use user defined parameters to set a filename and a sheet name.
This is a simplified workflow:
This is a parameter I use:
and this is schema settings for FeatureReader
It gives me the following error:
Here is my test example
Best answer by takashi
Hi @victorddt, it doesn't seem that the FeatureReader treats the feature type name "INPUT" well. I would recommend you to contact Safe support to clarify what happened FME internal.
  • Sep 17, 2019 3:06 AM UTC
itay
Forum|alt.badge.img+19
  • Sep 17, 2019 6:57 AM UTC
Hi @victorddt,
Strange just trying to read the xls with a reader results in an error, possibly there is something wrong with the file you have provided. (using FME 2019.1.0.0)
  • Sep 17, 2019 9:26 PM UTC
Hi @victorddt,
Hi @itay. I use the same FME version. Have you tried my test file? It's attached below.
itay
  • Sep 18, 2019 6:10 AM UTC
Hi @victorddt, Yes that's the one I have used to try the workspace and a completely new workspace just trying to read the xls file.
Saving the file with INPUT2 seems to solve the problem, So I guess @takashi had it right the all time :)
fmelizard
Forum|alt.badge.img+22
  • Sep 19, 2019 9:25 PM UTC
Hi @victorddt Yes, INPUT isn't a valid sheet name. I've filed FMEENGINE-61539 about this.
  • Sep 20, 2019 12:29 AM UTC
@danatsafe Thank you for registering the ticket. I have tried to change the sheet name from "INPUT" to "MYDATA" and update the parameter and Excel accordingly.
Same result - I can see only "no schema" list.
fmelizard
  • Sep 20, 2019 8:26 PM UTC
Hi @victorddt MYDATA works for me. I think you just need to set the Features To Read on the FeatureReader.
