Excel output formatting
roberto
Hello.
I need to apply some formatting to an excel file (borders, fontstyle and so on). So far I use a template but the solution is not perfect because I don't know in advance some details like, for example, how many rows will be written. Can I run a macro written into the template to accomplish these tasks? A shutdown python script?
Suggestions?
TIA
Roberto
itay
Forum|alt.badge.img+17
  • August 9, 2016
You can try the formatting options available on the writer feature type.
http://docs.safe.com/fme/2016.1/html/FME_Desktop_Documentation/FME_ReadersWriters/xlsx/user_attributes_w.htm
roberto
  • August 10, 2016
Thanks. Useful for some of my needs. Unfortunately I can see there the possibility also to specify border styles (v. 2015.1).
mark2atsafe
Forum|alt.badge.img+49
  • August 10, 2016
Hi @roberto - I don't see the ability to set a border either, but I do see that ability in the underlying library that we use. So I'm hopeful that if you file an enhancement request (safe.com/support) we might (no guarantees) be able to implement that fairly easily. Also let us know of any other options you need that aren't currently supported.
Regards
Mark
Product Evangelist
Safe Software Inc.
roberto
  • August 10, 2016
Regards
Mark
Product Evangelist
Safe Software Inc.
Hi Mark.
Thanks for suggestion. I will do it.
Rregards
Roberto
Thank you for your help. It was useful
