Excel formulas
  • Sep 30, 2013 11:19 PM UTC
  • 179 views
There is a way to write in a attribute an excel formula?
For example to write =MEAN($C$2:C@Value(_result)), where result is another attribute.
I tried with text, varchar attribute types when writing but didnt work.
fmelizard
Forum|alt.badge.img+22
  • Oct 1, 2013 6:27 AM UTC
Using your formula I was able to write to both the new and old XLS writers, the attribute data type is string.
See https://www.dropbox.com/s/vvp0u615iatyp4u/Excel_formulas.fmw
  • Feb 8, 2014 12:06 AM UTC
Trying to do this with FME 2013 SP3 and Office 2003 without success. Also tried the demo workspace so either there was a regression or it only works with newer versions of Excel.
  • Feb 12, 2014 8:57 PM UTC
There is a naming convention for formulas explained here: http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000csahAAA
danstevens
Participant
  • Participant
  • Jan 7, 2016 8:27 PM UTC
I realize this is an old question, but none of the existing replies helped me find the answer (thankfully it was documented).
You need to store the formula in a separate attribute named <AttributeName>.formula
So if you want a column named Total to be the result of a formula, create an attribute called Total.formula and populate it with your formula, e.g. =SUM(A2:B2)
http://docs.safe.com/fme/html/FME_Desktop_Document...
