The Esri ArcGIS Portal Feature Service Reader has most of the capabilities needed to read from a Utility Network including being able to set branch versioning. However there doesn't seem to be a way to resolve domains that are defined at the subtype. The Utility Network uses the subtype layer concept where domains can be applied differently on each field by subtype. Is accessing the subtype domains something the FME can/will support?
Esri Utility network reader subtype layer
Best answer by sammy
sammy wrote:
Has there been any update for resolving the Asset Group Subtype?
I am using Workbench 2023.1 and I am running into the same issue (Asset Type resolving but Asset Group not resolving). I am reading in Utility Network data with an Esri ArcGIS Portal Feature Service Reader. Currently, I am using a look up table to get the description for that field but would prefer to not have to do that for each of table/feature class in Utility Network.
Actually, I only just saw the comment to expose "arcgisonline_subtype_name" format attribute and that appeared to work so I do not need the look up table for the Asset Group subtypes anymore. Yay!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
