Error with ORACLE integration
  • Dec 12, 2018 8:38 AM UTC
  • 199 views
geo-x
Dear FME community.
I try to integrate data into ORACLE but FME say me : error was `ORA-29875: failed in the execution of the ODCIINDEXINSERT routine
Do you know what does that mean ?
Thanks
Best answer by itay
Hi @lalandexavier,
This usually means that the coordinates of the features are within the table tolerance and therefore Oracle rejects the features or cannot create the spatial index.
I suggest changing the tolerance of your table by re creating the tabel's entry in the user_sdo_geom_metadata table or making sure the coordinates are within the acceptable tolerance try the Generalizer transformer.
Hope this helps,
Itay
  • Dec 12, 2018 8:42 AM UTC
What happens if you try inserting a GeometryRefiner just before the writer?
itay
Forum|alt.badge.img+19
  • Dec 12, 2018 9:08 AM UTC
Hi @lalandexavier,
Hope this helps,
Itay
geo-x
  • Dec 12, 2018 9:55 AM UTC
That doesn't work better with the GeometryRefiner
geo-x
  • Dec 14, 2018 9:43 AM UTC
Hi @lalandexavier,
Hope this helps,
Itay
Thank you great !
This is my request :
DELETE FROM user_sdo_geom_metadata WHERE TABLE_NAME = 'MYTABLE';
INSERT INTO user_sdo_geom_metadata (TABLE_NAME,COLUMN_NAME,DIMINFO,SRID) VALUES ('EDTG_BATI_PARKING','GEOMETRY',MDSYS.SDO_DIM_ARRAY(MDSYS.SDO_DIM_ELEMENT('X',-2147483648,2147483647,5E-5),MDSYS.SDO_DIM_ELEMENT('y',-2147483648,2147483647,5E-5),MDSYS.SDO_DIM_ELEMENT('z',-2147483648,2147483647,5E-5)),2154);
DROP INDEX EDTG_BATI_PARKING_ARCH_GMIDX;
CREATE INDEX EDTG_BATI_PARKING_ARCH_GMIDX ON EDTG_BATI_PARKING
(GEOMETRY)
INDEXTYPE IS MDSYS.SPATIAL_INDEX
NOPARALLEL;
