Error with ODBC connection on FME Server
  • Aug 27, 2015 6:24 PM UTC
  • 75 views
apence231
Forum|alt.badge.img+10
I have an ODBC connection to a table that geocodes addresses and writes it to an ESRI ArcSDE feature class. When I run my workspace on my desktop everything works fine, as soon as I upload it to my FME Server I get this error:
Database Error Message: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
It's a System DNS connection and I checked all the drivers and 32bit connections and everything is good. So not sure what is causing it not to work on the FME Server. Thanks!
Best answer by jubert
have you sorted it out? I think this would fall under a "FME support" type of question
  • Sep 25, 2015 6:24 AM UTC
