Error while connecting from Data Inspector for Oracle Spatial 11g DB.
  • December 12, 2012
  • 31 views
spalatla
We are trying to view in FME for connecting the Oracle Spatial data. We are encountering issues when connecting.
Can you suggest while looking at the log.
The following is FME  connection error
FME Data Inspector Version 4.0
Loaded module 'OCI' from file 'OCI.dll'
Environment variable ORACLE_HOME has value `D:\\Oracle11gDatabase\\product\\11.2.0\\dbhome_1'
Connecting to ORACLE database `pgeprim' with user name of `GRBGAE' and password of `***'
Error connecting to Oracle database: message was `ORA-01017: invalid username/password; logon denied'. (serverType=`ORACLE8i', serverName=`pgeprim', userName=`GRBGAE', password=`***', dbname=`')
Failed to open database with username='GRBGAE', retrying using uppercase username
Connected to ORACLE database `pgeprim'
Oracle database version is '11.2.0.1.0'
Merged 17 schema features read from 1 datasets into 17 resulting feature types
Opening dataset pgeprim (ORACLE8I)...
'ORACLE8I' reader was created successfully
FME Configuration: Source coordinate system for reader R_2[ORACLE8I] set to `Belge1972-LB'
Coordinate System `Belge1972-LB' parameters: CS_NAME=`Belge1972-LB' DESC_NM=`Belgium National System 1972,(Lambert Belgian),RNB 1972 datum' DT_NAME=`RNB72-7P' GROUP=`EUROPE' MAP_SCL=`1' ORG_LAT=`90' ORG_LNG=`4.35693972222222' PARM1=`51.1666666666667' PARM2=`49.8333333333333' PROJ=`LMBLGN' QUAD=`1' SCL_RED=`1' SOURCE=`European Petrolem Survey Group' UNIT=`METER' X_OFF=`150000.013' Y_OFF=`5400088.438' ZERO_X=`0.001' ZERO_Y=`0.001'
The dataset 'pgeprim' was opened successfully
ORACLE Reader: Using Oracle 8 SC Reader to read tables from database `', server type `ORACLE8i', server name `pgeprim', user name `GRBGAE', password `***'
ORACLE Reader: Using Rich geometry.
Column `GEOMETRY' of table `GRBGAE.SURFACE_GEOMETRY' has been chosen to hold the geometry
ORACLE Reader: Executing SQL Statement `SELECT "GRBGAE"."SURFACE_GEOMETRY".* FROM "GRBGAE"."SURFACE_GEOMETRY"' to obtain features for feature type `GRBGAE.SURFACE_GEOMETRY'
Loaded module 'ociunk_geomedia' from file 'C:\\Program Files\\FME\\plugins/ociunk_geomedia.dll'
NOT changing coordinate system of reader identified by keyword `R_2' from `Belge1972-LB' to `' -- mapping file setting of `Belge1972-LB' overrides coordinate system `' read from file
Storing feature(s) to FME feature store file `C:\\DOCUME~1\\mlanka\\LOCALS~1\\Temp\\FFS_1355226901782_3020'
Could not understand type information: type=101, size=8, scale=0, precision=0
... Last line repeated 2 times ...
Column `GT_REFERENCE_POINT' of table `GRBGAE.SURFACE_DATA' has been chosen to hold the geometry
ORACLE Reader: Executing SQL Statement `SELECT "GRBGAE"."SURFACE_DATA".* FROM "GRBGAE"."SURFACE_DATA"' to obtain features for feature type `GRBGAE.SURFACE_DATA'
Unable to define column number 9: error was `ORA-01024: invalid datatype in OCI call'. (serverType=`ORACLE8i', serverName=`pgeprim', userName=`GRBGAE', password=`***', dbname=`')
Failed to read features from 'pgeprim' using 'ORACLE8I' reader.
Stored 154 feature(s) to FME feature store file `C:\\DOCUME~1\\mlanka\\LOCALS~1\\Temp\\FFS_1355226901782_3020'
The 'pgeprim' dataset was closed successfully
The 'ORACLE8I' reader was destroyed successfully
Please suggest where we are going wrong.
Regards,
SPALATLA.
Best answer by davideagle
Firstly, FME resolves the issue for you but the username/password you are entering is in the wrong case. The main issue though appears to be the ORA-01024 issue, this is what that means:
 ORA-01024:	invalid datatype in OCI call Cause:	An OCI program call specified an invalid datatype. In OCI calls, Oracle datatypes are specified as numbers between 1 and 7. Action:	Check the datatype description and enter the correct number for the datatype.
Can I suggest you ensure that your database tables have the correct datatype defined for their content, specifically it looks like their might be an issue with col9 in GRBGAE.SURFACE_DATA?
davideagle
Forum|alt.badge.img+21
  • December 14, 2012
