Error was 'ERROR: extra data after last expected column POSTGIS
  • November 29, 2018
  • 5 replies
  • 839 views
amolparande
I am trying to create schema and upload data to PostGIS facing Error
2018-11-29 09:18:58| 13.8| 0.1|ERROR |Bulk copy failed on table 'FIN.match_tt' using delimiter ':'. Error was 'ERROR: extra data after last expected column
CONTEXT: COPY match_tt, line 1: "00004649-3100-0400-0000-0000000ab870:30:5.39508913314117:85.76780709963086:80.37271796648969:5.05078..."
2018-11-29 09:18:58| 13.8| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2018-11-29 09:18:58| 13.8| 0.0|ERROR |Bulk copy failed on table 'FIN.match_tt' using delimiter ':'. Error was 'no COPY in progress
2018-11-29 09:18:58| 13.8| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details"
can any one help
Please find log file for reference.
  • November 29, 2018
I think you'll have to make a support case with your FME provider or through our support web page. You'll have to include some sample data from the source File Geodb, your workspace and also the table create SQL for the table match_tt.
This PostGreSQL error seems to occur if there is a mismatch between the number of columns being written and the number of columns in the target database. This might occur if the database table definition has changed since created the feature type in the workspace. Perhaps check that the Feature Type does match the database table schema.
oscarwillems
Forum|alt.badge.img+15
  • February 20, 2019
I have the same problem, and it is because one of the text fields contains the delimiter ( : ), in my case a http link as a value contains a delimiter.
  • February 20, 2019
@oscarwillems I couldn't reproduce this issue when writing to PostgreSQL. Testing FME in 2018 & our 2019 beta I could write a 'text' data type with a URL then read it back in data inspector:
url (encoded: UTF-8) https://www.safe.com/
oscarwillems
  • February 21, 2019
Using 2018.1, with me it occurred with a PostgreSQL FeatureWriter and a text field with an URL, and "Bulk insert" set to YES (so it will bulk insert with a : delimiter), I'll try to get you a snippet if I work on the problem again, for now, I just skipped the bulk insert and it works.
yes correct
