error ORA-01742 comment syntax
  • Jul 26, 2016 7:24 AM UTC
  • 99 views
I'm using a SqlExecutor deleting some data in a Oracle database.
FME_SQL_DELIMITER ;
--feuille 1
DELETE FROM G_ADT_AGRI.EXP_INVEST WHERE OBJECTID = @Value(OBJECTID);
--feuille 2
DELETE FROM G_ADT_AGRI.FON_BATI WHERE OBJECTID = @Value(OBJECTID);*/
As you can see I commented the "feuille2" part. But I have this error message :
An error occurred while accessing a table result for feature type `QueryFactory_SQLExecute'; message was `Execution of statement `/*
--feuille 2
DELETE FROM G_ADT_AGRI.FON_BATI WHERE OBJECTID = 699' did not succeed; error was `ORA-01742: comment not terminated properly
Although I use the right comment syntax. What did I miss?
Best answer by david_r
The SQLExecutor (or the Oracle driver, I'm not sure) doesn't like comments. Remove the comments and it should work.
  • Jul 26, 2016 7:27 AM UTC
  • Jul 26, 2016 8:11 AM UTC
Indeed if I remove the /*...*/, it's fine. Thanks.
It seems that is the Oracle driver because with a Postgresql database, it works.
Is that a known bug in Safe?
  • Jul 26, 2016 8:21 AM UTC
Not sure, but the issue has been mentioned here before.
