'ERROR: null value in column "objectid" violates not-null constraint - postgres/ArcSDE
  • Mar 27, 2020 11:23 AM UTC
  • 359 views
raaaju1990
Forum|alt.badge.img+11
I have an ArcSDE geodatabase on postgres. Im using a feature writer to insert records in an existing feature class.
While doing so, I get the below error 'ERROR: null value in column "objectid" violates not-null constraint'
When I drop the table and create new while writing, I get no errors.
Logically, the sde should autogenerate this objectid field whenever I insert a new record. Am I right or where am I going wrong?
Please suggest
Thanks
oscard
Forum|alt.badge.img+23
  • Mar 27, 2020 11:26 AM UTC
That's weird.
FME ignores the OBJECTID value even if you pass it to the Writer.
Is the OBJECTID in the attribute list of your Writer? I would remove it just in case.
  • Mar 27, 2020 11:50 AM UTC
Are you using the POSTGRES or the GEODATABASE_SDE writer format in FME?
Only ESRI writers will automatically populate the OBJECTID values, with any other writer (e.g. POSTGRES) you will have to manually specify the value.
If you are using the GEODATABASE_SDE writer, it would be helpful if you could post the FME log here.
