Error message while writing to a relationship geodatabase "Failed to retrieve origin row for a relationship feature with OBJECTID '1' from table/feature class"
  • Apr 29, 2019 6:39 PM UTC
  • 183 views
Hello,
I created a FGDB that has a Feature Class, Relationship Class and Related Table. I used this url https://knowledge.safe.com/articles/28340/working-with-geodatabase-relationship-classes-atta.html) as a reference to set up the FME workspace to write data to the feature class and related table. What is interesting is that it writes without errors if I only write to the feature class and related table. If I try to also write to the relationship class writer, then I get this message. "Failed to retrieve origin row for a relationship feature with OBJECTID '1' from table/feature class" This makes me wonder if in this situation I don't need to write to the relationship class. If I do, hopefully someone can provide an answer as to why I am getting this error.
Kind Regards,
Laura
trentatsafe
Forum|alt.badge.img+7
Hello @lmawhinney7175,
Are you able to share the XML Workspace Document or your target Geodatabase? I suspect this might be as a result of the Relationship type as you thought.
This article you used should provide some context regarding which relationships requiring the relationship table to be written to directly. In particular, the relationship background section. I've re-linked the article here for you - https://knowledge.safe.com/articles/28340/working-with-geodatabase-relationship-classes-atta.html
Hi @trentatsafe I have the same issue and I referred to that document with no luck.
Can you please listed what are the option to solve this issue?
