Error: FME EXE has stopped working
  • August 29, 2019
  • 6 replies
  • 30 views
amolparande
Hello FME Users,
i am using FME Version 2019.0.2.0 WIN 64 bit windows 10 . now days i am facing "FME EXE has stopped working" frequently mostly "WorkspaceRunner" & Workbench itself also facing do any one has solution why this is so
Best answer by itay
I find purging the temp files (Tools menu > Purge Temporary Files) sometimes help.
Is it also happening when running the translation without feature caching?
Forum|alt.badge.img+62
Is it always doing that or only with certain workspaces/datasets?
itay
Forum|alt.badge.img+18
  • August 29, 2019
amolparande
  • August 29, 2019
Yes without feature caching it's occurring .
amolparande
  • August 29, 2019
facing this issue for multiple systems not for any specific workspace.
itay
  • August 29, 2019
You can try turning the Log Debug on, to see if you get more information about the cause.
And open a support request https://www.safe.com/support/
jovitaatsafe
Forum|alt.badge.img+11
Hi @amolparande,
Sorry to hear that you've run into this issue. When you submit your case, please include:
  1. an FME Report generated from the system_information.bat file from General Troubleshooting | Gathering System Information
  2. a screenshot of your Windows crash event
Some things you can try in the meantime are to check that your graphics drivers are up to date. There's a bit more information from this previous Forum question.
Thanks!
Jovita
