Error connecting to Oracle database via FME Server
  • May 17, 2018 1:54 PM UTC
  • 128 views
benschmark
I get an Oracle connection error using FME Server 2017.1.2 - Build 17722 - win64 to import data to an Oracle Spatial 11g or 12c database. The server OS = Windows Server 2008 R2
The following Oracle Server settings are present:
tnsnames.ora is set via an environment system variable to a certain drive mapping:
TNS_ADMIN %O_DRIVE%\\Oracle
O_DRIVE \\\\srv_name\\environment\\app
ORA_HOME not set
Locally tnsnames is NOT set via:
<<Installation_Drive>>\\app\\Administrator\\product\\<<versiono of Oracle>>\\client_1\\network\\admin\\tnsnames.ora
When I copy tnsnames.ora locally FME SRV connects without problem (which we don’t want), if ORACLE_HOME is set or not doesn’t matter.
When tnsnames.ora is set via TNS_ADMIN variable and NOT locally FME SRV oracle connection fails.
FME Workbench doesn’t have this problem, it connects to TNS_ADMIN without problems.
Is there a solution?
Hi @benschmarkbvba
We have a troubleshooting guide here which may help.
Does the account running the fme server engine in with down services have permissions to your database?
If that doesn't help, it'd be useful to see which errors you're getting
benschmark
  • May 17, 2018 2:16 PM UTC
Hey,
I've checked the guide already, without success.
Account permissions should be ok, i'm admin.
oracleissuefmesrv.zip
i've uploaded 2 log files:
job_17485 > no TNS issue (tnsnames.ora is set locally)
job_17488 > TNS issue (tnsnames.ora is NOT set locally)
Regards,
Raf
benschmark
  • May 17, 2018 3:32 PM UTC
Hi @benschmarkbvba
Jennifer,
Were the logs helpfull? Or do you need more feedback?
Regards
Raf
