Enlarging the “text” that appears in the “FME Data Inspector” from the “workbench”,
  • Sep 11, 2014 10:47 AM UTC
  • 82 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out if there is a way to enlarging the “text” that appears in the “FME Data Inspector” from the “workbench”.
For example, the “text” output below appears in small size, how to enlarge its size from the “workbench”?
Thank you
Best
Jamal
Best answer by gio
use a labelpointreplacer?
  • Sep 11, 2014 11:08 AM UTC
Have a look at the Scaler. You should set a value of greater 1 (e.g. 1,5 to get a 50% higher label) for X and Y and check the output in the Inspector. If you have hight information, you also could set the Z value.
I use this transformer for example to output MapInfo text labels. The challenge is to test for the various parameters (like "Location and Size" or "Lacation only") and to see the end result in the Inspector.
Kind regards
Thomas
gio
Forum|alt.badge.img+15
  • Sep 11, 2014 11:09 AM UTC
jamal
  • Sep 11, 2014 11:27 AM UTC
Many thanks for the help guys. It works fine with the “LabelPointReplacer”
Best
Jamal
