Elasticsearch writer doesn't support authentication?
  • Feb 19, 2018 8:33 AM UTC
  • 5 replies
  • 72 views
Forum|alt.badge.img+3
I have an elasticsearch instance that requires a password for writing. Am I understanding this correctly that FME can't write to a secure elastic search?
Best answer by brianatsafe
Good news! We've added this (basic authentication) in the 2019 beta (b19151). It also allows Elasticsearch to be used as a web connection.
Please let us know if there are any issues.
@janb FME does not yet support authentication for Elasticsearch (as of FME 2018 and earlier). Can you confirm if your database is using X-Pack (formerly Shield) , or are have you implemented an alternative authetication plug-in?
  • Apr 11, 2018 9:11 AM UTC
Hi Mark
I don't know a log about Elastic search so forgive me if I am not able to answer your question in lots of details. we are using the https://readonlyrest.com/ for authentication.
  • May 14, 2018 3:21 PM UTC
Hi Mark
since authentification for Elasticsearch is currently not possible: what would you recommend doing? We do not have an authentication plugin for elasticsearch implemented yet, but we will.
- what could we do now in order to write into shielded elasticsearch?
Thanks!
I am currently trying to use an cloud elasticsearch (test instance on elastic.co) instance with fme. It requires authentication.
Is there any plan to implement security with elastic?
Thanks.
Vincent,
Elastic&cloud;: https://www.elastic.co/cloud/elasticsearch-service/signup?elektra=start
brianatsafe
Forum|alt.badge.img+13
  • Nov 28, 2018 10:28 PM UTC
