ECW writer: This format does not support writing the RGB/RGBA bands in the raster with other extra bands.
  • Mar 27, 2018 3:11 PM UTC
  • 121 views
I have an 8-bit raster image (jp2) which I need to convert to ecw format. A fatal error occurred and the message was "ECW writer: This format does not support writing the RGB/RGBA bands in the raster with other extra bands. Please remove the extra bands and try again". How can I fix it?
LizAtSafe
Forum|alt.badge.img+27
  • Mar 27, 2018 3:19 PM UTC
Hi @ilmachairas,
Here is an article to get you started: How to Convert GeoTIFF to ECW
It goes into detail about how to change band types and how to add/remove specific bands specifically for converting to ECW.
The main transformers you would use in this situation would be the:
Hopefully that helps,
-Liz
