Dynamically writing to DWG
  • Nov 13, 2018 3:37 PM UTC
  • 159 views
bjudes
Forum|alt.badge.img+10
I have a file geodatabase, I am filtering various features from this and am writing it to DWG. However, I want to break down this single file geodatabase into multiple DWG tiles. I am currently using a clipper to clip to my new tile boundaries, when I go to write however I cannot name multiple tiles with different names because I also want to name the various layer names dynamically. Is there a way I can name the tile for example write multiple tiles (eg. 1234, 1233, 1235) and name the layers individually as well?
I hope this makes sense, please feel free to ask questions if it doesn't. It's hard to explain over the internet.
Thanks so much for any help.
B
Best answer by gio
@bjudes
Use the fanout expression. There you can fanout per tile.
See writer parameters in the Navigator panel of the autocad writer.
gio
Forum|alt.badge.img+15
  • Nov 13, 2018 4:52 PM UTC
@bjudes
mark2atsafe
Forum|alt.badge.img+59
As @gio says, use the Fanout option in the Navigator window:
Here, for example, I have a set of park features. I get a single DWG each neighborhood and each park is written to a separate layer within the DWG file.
bjudes
  • Nov 14, 2018 9:27 AM UTC
Thanks Mark, worked perfectly. Always great help here.
bjudes
@bjudes
Thanks Gio, worked perfectly. Always great help here.
