Hi All, First of all, tanks for reading my post.
FME Desktop 2022.2
Objective: Using the Feature Reader I’m trying to dynamically have a user input an existing sde table name (so the user is prompted to insert the table name that already exists), then I have a reprojector followed by the FeatureWriter to Drop and Create the table in a new projection. The table to be dropped an create will be the same one inserted by the user. Hence, this table already exists.
Error: ‘Feature Type Definition {feature here} was requested, but not defined’. I checked another similar post, but I still can’t get my workbench to work.
I have a Feature Reader set as follows:
When I run the workbench, the FeatureReader does not show the table name that was inserted by the user, but instead, it catches the table records under ‘Generic’ see screenshot below. (If I were to access that table statically (connecting to the table via the SDE connection), then the table name will display along with it’s schema definitions columns and attributes).
When I inspect it, it shows like this below. Notice there no schema displayed such as the column name and its attributes, however, it does pick up the geometry points.
Feature Writer: Notice I have fme_feature_type as the feature class. This contains the value of the table that the user entered.
Under User Attributes tab I have the attribute definition set to Dynamic, but it does not show the columns field names.
When I run it, I get the error:
I’ve also tried the $(TableName) parameter on the FeatureWriter feature class but still get the same error.
However, If I set the attribute definition to Automatic, then the Feature Writer Parameters automatically change
Notice how the Geometry is automatically changed to geodb_point and the dynamic schema definition is disabled :
When I run this, it runs successfully, the table is dropped and created with the new projection but it is missing the schema (column field names and its attributes).
Question: What else can I do to get this working? I don’t want to create Staging table then having to go back and rename tables etc.
Thank you.
