Dynamic write to ArcSDE Geodatabase
  • Aug 22, 2013 3:07 PM UTC
  • 0 replies
  • 25 views
sigtill
Forum|alt.badge.img+25
I am writing to a ArcSDE Geodatabase with many Features. I want to make sure that only the existing features gets written - for instance:
MyRoadsPoint
MyHousePoint
MyParkArea
So if I create a feature_type called MyParkPoint and try to write this - it will fail because the MyParkPoint does not exist in this database.
Is there a setting on the writer I have not seen?
One solution might be to add the existing allowed FeatureTypes - however the allowed FeatureTypes and the Output database will chang between every run.
