DWG Writer Attribute from shape output?
  • Sep 7, 2017 12:38 PM UTC
  • 38 views
I want to expose the attributes of a esri sde30 to a dwg writer.
How are the Settings of the dwg writer:
Parametres>Advanced>Attribute Output:
Or someware else?
danilo_fme
Forum|alt.badge.img+58
  • Sep 7, 2017 2:41 PM UTC
hi @dirk1964.
Yes, you are correct. Only check the name of attributes are correct between your Reader and Writer.
Thanks,
Danilo
