DWG points to symbols?
  • Jan 7, 2016 3:26 PM UTC
  • 6 replies
  • 82 views
I have a DWG file containing wells, trees, mast etc. They are symbolized using points but my users would like if it would be possible to use symbols instead of points. How can I do that? Thanks! Christian
erik_jan
Forum|alt.badge.img+26
  • Jan 7, 2016 3:57 PM UTC
The transformer DWGSTyler will allow you to define BLOCKS for point objects.
You will need a template file containing the block definitions and then you can pick the block by name from the template.
davideagle
Forum|alt.badge.img+21
  • Jan 7, 2016 4:01 PM UTC
Assuming each point has some sort of differentiation within the data to discern the difference, such as an ID, a classification type, or even a colour, then you'll be able to filter off each feature by type. Wells go one way and trees go another etc...
Once filtered you can either send the features to a different DWGStyler each and apply some AutoCAD 'Blocks' that one of your colleagues might be able to prepare for you and save into a template file... like this:
Or alternatively you could set the DWG block attributes yourself with an AttributeCreator, autocad_block_name for instance.
Or if you are a bit more advanced then using the SchemaMapper and looking up the styles from a spreadsheet you've designed is also a very useful approach.
Good luck.
davideagle
  • Jan 7, 2016 4:03 PM UTC
Good luck.
How about that, two almost identical answers, posted at almost the same time from different continents... The power of the interweb :0)
erik_jan
  • Jan 7, 2016 4:06 PM UTC
If was a little faster, but only because I did not take time to fill in the blanks.
fmelizard
Forum|alt.badge.img+22
  • Jan 7, 2016 9:04 PM UTC
So if two great answers come in at the same time, how can the moderator pick a "best answer"????
davideagle
  • Jan 7, 2016 9:37 PM UTC
Very carefully!
