DWG Layer Order
  • May 12, 2020 3:14 AM UTC
  • 128 views
deanhowell
Forum|alt.badge.img+24
Is there a way to control the order of layers that are output to the DWG Writer or is that controlled by the DWG Template used?
I have a number of layers say A,B,C but I want the DWG output to be B,A,C.
If I output to a PDF the order of the layers is the order they appear in the PDF Output but if I send the same layers and order to the DWG they are ordered in the same order as the template. My guess is I just need to change the order in the template but just wanting to see if anyone knows of a way in FME.
Thanks
Dean
erik_jan
Forum|alt.badge.img+26
  • May 12, 2020 4:46 AM UTC
@deanhowell, you are right: the order is the same as in the used AutoCAD template file.
To change the order, you will have to change the template.
deanhowell
  • May 12, 2020 4:48 AM UTC
Thanks @erik_jan. I appreciate you confirming.
