DWG format attributes for hatch colors
  • November 7, 2014
  • 31 views
I want to set hatch layer fill colors which are defined by  number values in the attribute “extended_data{1}.32Bit_integer{0}” (this option is not in the DWG styler), and I would like to edit the values of the data_list and extended_data attributes for a large number of map material that I am going to import.
Most of these DWG-attributes from CAD are removed during transformation. Is there a way to add, keep and set these attributes in FME? Directly adding them as user attributes did not get recognized in the writer.
The single “autocad_extended_data_list{}” is present as a format attribute but nothing else.
Best answer by gio
All the attributes are available on the dwg reader.
U need to expose them on the "format attributes" tab on the reader ( a large list)
U can also use an attributeexposer, this is particularily hadny if u are well known with the autocad format and can type in what u need by heart.
Very usefull in this respect is FME readers and writers bible "autocad" section.
http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm
This book explains what can and niot be done with the attributes.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
gio
Forum|alt.badge.img+15
  • November 7, 2014
