dwg conversion
  • August 3, 2019
  • 5 replies
  • 52 views
kathir
I Have a dwg file. I need split that into multiple dwg based on the used autocad layer.
pratap
Forum|alt.badge.img+12
  • August 3, 2019
use Fanout option in writer. Use the attribute autocad_layer in format attributes of DWG reader
kathir
  • September 27, 2019
hi thanks for the reply. but the output data stored only file format. its not take dwg format automatically
Forum|alt.badge.img+46
If you create a new attribute by joining the autocad_layer with .dwg and fanout on that the output should be as you require
kathir
sorry. i cant understand what you told.can you send any example
jovitaatsafe
Forum|alt.badge.img+11
  • September 30, 2019
Hi @kathir,
There are some examples in the documentation for Setting Feature Type Fanouts, and a downloadable workspace template example in our Fanout article. Hope that helps!
