draw polyline/ set global width value in polyline
  • Mar 17, 2017 3:42 AM UTC
  • 110 views
Hi All,
I want to draw a polyline that is defined in a layer of my template file. but dwgstyler has only got lines as options.
How do I draw a polyline using 'DWGstyler' or any other transformer?
Thanks in advance.
  • Mar 17, 2017 4:42 AM UTC
I have drawn polyline from dwgstyler. However, the polyline drawn has a global width value of '0' whereas it is required to be '1.8'.
How can I set this value?
Thanks
taojunabc
Participant
  • Participant
  • Mar 17, 2017 4:45 AM UTC
The DWGStyler, like its name, just defines the style, Line Style is different from Line Geometry, it is not only applicable to Line, but also for Polyline.
taojunabc
Participant
  • Participant
  • Mar 17, 2017 5:02 AM UTC
Thanks
If you use a template file, you can set the line width in the template file, and then specify the template file in the DWG writer, and set the DWGStyle Line Weight to "By Layer".
