Draw lines between points
  • Aug 17, 2016 5:27 PM UTC
  • 741 views
I have an object that has that has two Point styles. I can translate point styles into cells in Microstation but I would like to generate a line that will go between the two cells. To be honest I am not sure where to even start. Any help would be appriciated
erik_jan
Forum|alt.badge.img+26
  • Aug 17, 2016 5:36 PM UTC
Have a look at the PointConnector transformer. One of the settings is the attribute to be used as the connection break. So if you can group the points by an attribute you can create lines per group.
erik_jan
  • Aug 17, 2016 5:41 PM UTC
Or if the two points are combined in one object, you want to check out the VertexCreator, using the point X and Y to create the start and end points of the line.
Thanks for this, PointConnector worked great.
By using the PointConnector transformer I was able to get this to work.
Thanks
