Does SQLite spatial writer support UTF-8 characters?
  • Jun 24, 2014 1:46 PM UTC
  • 79 views
Does anyone know whether it is possible to write UTF-8 data to Sqlite spatial?
You get the option to specify encoding when using the Spatialite writer but not the Sqlite spatial writer?
Any ideas?
Thanks
  • Jun 24, 2014 3:16 PM UTC
why not do a small test? I'd be very surprised if it didn't support UTF-8.
David
  • Jun 24, 2014 3:25 PM UTC
Hi David
I have run a small test with some data with utf-8 Greek characters and these are not reproduced correctly when using the standard SQLite spatial writer. I'm using FME desktop 2013 sp2. Does anyone know if there is a workaround for this.
Thanks
James
  • Jun 24, 2014 3:54 PM UTC
are you using the "Spatialite" or the "SQLite Spatial (FDO)" writer?
I suspect the Spatialite writer is newer. It will let also you specify the character set.
David
  • Jun 24, 2014 4:14 PM UTC
Hi David,
I have run tests with both,
Spatialite will create data in UTF-8, but it's structure is different and cannot be read by applications such as MapInfo pro
SQLite spatial can be read by MiPro, but the writer seems to be unable to write with UTF-8, as far as I can tell, unless anyopne knows of a work around
I guess that's where I am,
