Does anyone know how to get the connected pipe data from Civil 3D structures to to populate as an attribute to the structure
  • Apr 3, 2019 3:17 PM UTC
  • 66 views
I can get the inverts of the pipes in the pipe features, but i need the data to populate with my structure feature and when looking at the format attribute table for structures I don't see those attributes available
daveatsafe
Forum|alt.badge.img+24
  • Apr 4, 2019 8:23 PM UTC
Hi @jjohnson1119,
The pipes have the start and end structure ids on them (aec_pipe_start_struct_id, aec_pipe_end_struct_id). You can use these ids to merge the pipe inverts on the structure attached to the pipes (merge to aec_object_id on the structure), using a FeatureMerger transformer.
