Docs on how to utilize "Shared FME Folders" for custom formats ?
lifalin2016
Forum|alt.badge.img+29
"Shared FME Folders" is a great way to share setups between 32/64 bit instances, between versions, even between colleagues on a network drive if warranted.
It seems that there are much documentation on how to share database connections and coordinate systems using these "shared folders". And I even got the shared "Transformers" working.
But how do I add and share a Python based custom format using "shared folders" ? Apparently not by just copying the formats folder into "Formats" !
It seems that information about formats need to be stored all over the place, typically under "FME_HOME", which is of course not shared. I've seen format information stored in sub folders "formatsinfo" and "metafile", and the format functions themselves (py/pyc files) need to be in a 3rd place.
Are there any comprehensive documentation on how "shared folders" work ? And on whether it can fully accomodate custom formats without the need for storing files under "FME_HOME" ?
Cheers
Lars I.
Best answer by redgeographics
You'll need to put the .fds file in the formats folder but also edit the formats.db and gallery.db files in your FME installaton directory. There's a formats.txt file in there that has documentation on that.
Before you do that I highly recommend you make a backup of those two files, just in case.
lifalin2016
  • April 24, 2018
Any progress on this issue in the recent year ?
Forum|alt.badge.img+50
  • April 24, 2018
lifalin2016
  • April 26, 2018
I know, but these files and folders are not included in the "Shared FME Folders", so unfortunately this is not an answer to my query.
I understand your point, but I’m afraid that’s how it works at the moment.
