Do you need to start with a dynamic workspace to create an FME workflow that dynamically filters data from a postgresql database published as an FME app with end user parameters?
  • Jun 25, 2025 12:58 AM UTC
  • 164 views
andersonkma
Forum|alt.badge.img+4
I would like to publish the app so that the end user can optionally select a variety of filters including:
  • date ranges
  • static attribute fields (A or T)
  • dynamic input fields (for example if a new business code is added to the source data)
I have been able to publish the user parameters in the app but the data does not filter from the results set.
j.botterill
Forum|alt.badge.img+69
  • Jun 26, 2025 12:30 AM UTC
Have you placed and tested the user parameters in the workspace, prior to the server app. Refer to the FME Academy Advanced course unit “Create Flexible Workspaces with Parameters 2024.1” https://academy.safe.com/path/fme-form-advanced/create-flexible-workspaces-with-parameters and/or the user parameters section https://support.safe.com/hc/en-us/articles/27200008210317-Parameters-Across-the-FME-Platform
Providing a sample fmw workspace, or better a fmwt template with the feature cache, as an attachment, would help others provide better advice here
andersonkma
  • Jun 27, 2025 3:09 AM UTC
Thanks so much ​@j.botterill.  Yes, I have been able to run the date filters applying the steps you mentioned but I haven’t been able to get results for attributes filtered within the selected date ranges.  I’ll have another review of the articles though - thanks for the tips!
sanaeatsafe
Forum|alt.badge.img+9
Hi ​@andersonkma !
If the data isn’t filtering as expected after publishing the app, a few things to check:
  • Make sure your date values are in proper FME datetime format. Use a DateTimeConverter if needed.
  • For filtering, you can use a Tester, a SQL expression, or a WHERE clause directly in the reader if the source supports it (postgres will have all these options!)
  • To work with date ranges, the DateTimeCalculator can help set up comparisons (e.g. start/end ranges). Also, check out FME’s datetime functions (like @DateTimeNow(), @DateTimeAdd(), etc) if you need dynamic dates. Our article DateTimes and FME goes into more details on how to work with datetime attributes.
  • If you’re not seeing results, try using a Logger or Tester to verify parameter values are actually matching what's in your data.
Let me know if that helps or if you want to share more details!
Sanae
andersonkma
  • Jul 4, 2025 4:21 AM UTC
Thank you for the detailed explanation ​@sanaeatsafe!  I’ll give these options a try.  Stay tuned
