Directory and File Pathnames reader equivalent for files
  • Sep 18, 2018 8:05 PM UTC
  • 12 replies
  • 279 views
jdh
Forum|alt.badge.img+41
Is there an equivalent reader to the Directory and File Pathnames (DFP) that can take as source parameter a file, or files, including wildcards, and produce one feature for each file, but not actually read in the file.
Essentially it would be the DFP reader that can take a Filename (Multiple) parameter instead of just a folder.
My current workaround is to use the Text File Reader, whole file at once, but it's reading a bunch of data unnecessarily.
Forum|alt.badge.img+54
  • Sep 19, 2018 8:01 AM UTC
Can you not do this by using a FeatureReader and using Directory and File Pathnames format? You then have parameters available to use in the Path Filter
jdh
  • Sep 19, 2018 1:40 PM UTC
The Directory and File Pathnames format, regardless of whether it is in the FeatureReader or actual reader, will only accept folder names as an input, not filenames.
  • Sep 19, 2018 3:15 PM UTC
I'm maybe misunderstanding the problem, but if you have an input parameter with a filename, you can split this into the folder and the filename, the folder then provides the dataset for the featurereader and the filename can be used a a path filter
jdh
  • Sep 19, 2018 3:23 PM UTC
It may be a filename, it may be multiple filenames, it may have wildcards, or recursions. Basically any option from the filename (multiple) parameter.
For example, this could be the parameter:
""D:\\file1.txt" "D:\\a\\*.txt" "D:\\data\\**\\xyz.txt""
  • Sep 19, 2018 3:59 PM UTC
It appears to handle the wildcards with no issues,
e.g. from an input of ""C:\\temp\\file1.txt" "C:\\temp\\a\\*.txt" "C:\\temp\\unknown\\**\\*.txt""
It returns
C:\\temp\\file1.txt
C:\\temp\\a\\file2.txt
C:\\temp\\a\\file3.txt
C:\\temp\\unknown\\New folder\\file1.txt
jdh
  • Sep 19, 2018 4:04 PM UTC
It returns
C:\\temp\\file1.txt
I assume you split the filename parameter first on the " " beofe the FilenamePartExtractor?
  • Sep 19, 2018 6:24 PM UTC
I used a stringsearcher to get all the matches between quotes then exploded the list before the FilenamePartExtractor, but splitting the parameter would do much the same
jdh
  • Sep 19, 2018 6:25 PM UTC
What regex did you use?
  • Sep 19, 2018 6:29 PM UTC
I used "(.*?)" but also made use of the fact that you can manipulate the search in attribute to get rid of the first and last quote marks
jdh
  • Sep 19, 2018 6:44 PM UTC
I think the splitter is the better option, as this doesn't match the case where only a single file is present, and there are no quotes.
I had a similar situation where I was using the Directory and File Pathname (DFP) Reader in a workspace that created a feature and attachments to be added to a GDB. The DFP Reader provided the file metadata and a single record for each file necessary to create the attachment records. I wanted to execute this via email using FME Server which meant that I was no longer going to pass a folder as the parameter, but rather files directly (email attachments).
I used the Data File Reader as a substitute. I exposed the fme_basename and fme_dataset attributes and used an Aggregator Transformer to "Group By" fme_basename giving me a single record. I sub-stringed the extension off of the fme_dataset to create the path _extension, added it to the fme_basename to create the path_filename, and renamed the fme_dataset to become the path_windows.
It worked for my scenario. I write the feature and attachments to an SDE Feature Class used in some Web Apps. No duplication of attachments and they open correctly.
Hope this helps as a suggested solution that can be manipulated to fit your situation.
  • Oct 20, 2018 2:07 AM UTC
A path filter string could contain characters which can also be used in a path string, such as square brackets, curly brackets and comma. I therefore think it's hard to automatically split a text string into the two parts - a directory path and a path filter.
If you could an external table having two fields - directory path and path filter to specify the conditions, it could be a workaround to read the table and run the PATH reader via a FeatureReader for each pair of directory and filter. For example:
directoryfilterC:\tmpfolder_[A-C]\*.txtC:\tmp\a*.{txt,csv}C:\tmp\unknown**\*.txt
If you need to specify the pairs of directory and filter as a single parameter, probably you will have to use a special character which won't be used in both a directory path and a path filter as the delimiter between directory and filter. The pipe (|) could be a candidate.
"C:\tmp|folder_[A-C]\*.txt" "C:\tmp\a|*.{txt,csv}" "C:\tmp\unknown|**\*.txt"
