Difference between DatabaseUpdater and Feature Operation in Writer
  • Jan 8, 2021 4:34 PM UTC
  • 99 views
I'm wondering what the difference is between the DatabaseUpdater transformer and setting the Feature Operation to Update in a database writer.
I know there is a lot of overlap is some of the transformers in FME so i'm wondering if one is better or if they'll do the same thing.
caracadrian
Forum|alt.badge.img+23
  • Jan 8, 2021 6:10 PM UTC
DatabaseUpdater is designed to do one thing and do it really good.
A database writer (any type of database) can do a lot of things, it is universal/generic as it comes to db operations.
The logic usually is that a dedicated solution is faster than a more generic one. So that should be the answer.
Depending on how you set them up they should do the same thing in terms of updating.​
Great, thank you!
