Determine if a Writer which is an SDE layer is versioned?
  • Apr 17, 2019 6:36 PM UTC
  • 65 views
mmestrov
Forum|alt.badge.img+3
I need to figure out a way of testing if a writer which is an SDE layer is verisioned or not. If it is versioned I do not want to truncate and fill if from the reader but if it is not versioned then I would want to truncate and fill.
Best answer by erik_jan
Depending on what underlying database you are using.
This article explains how to determine this:
http://desktop.arcgis.com/en/arcmap/latest/manage-data/using-sql-with-gdbs/determining-which-data-is-versioned.htm
You can use the SQLExecutor transformer to perform the query.
erik_jan
Forum|alt.badge.img+26
  • Apr 17, 2019 7:08 PM UTC
mmestrov
  • Apr 17, 2019 7:44 PM UTC
The link does not work.
mmestrov
  • Apr 17, 2019 7:46 PM UTC
I was able to find it without the link. Thanks
erik_jan
  • Apr 17, 2019 8:17 PM UTC
Fixed it. Hope it works now. Not sure what happened.
