Detecting changes of the feature layer in AGOL
  • June 20, 2019
  • 70 views
syang
I have a feature layer in AGOL. What I try to do is when there is a new record added into the layer, the FME workspace published into the FME server can auto detect the changes, then trigger the workspace to run. FME Schedules can do the job, but not idea. Any ideas? Thank you.
@syang You would have to configure AGOL to send out a notification. I'm not sure if this is posisble - there seems to a few Ideas on Esri GeoNet regarding sending out an email notification when a change is detected. I think I'd reach out to your Esri support organisation to see if it possible to have AGOL send notifications. The problem is similar to any database that needs to be configured to send out a trigger when data changes.
It would be great if you could post back here if you do uncover a methodology
