Data sources in an ArcGIS project (aprx)
  • Apr 10, 2025 6:21 PM UTC
  • 272 views
creinier
Forum|alt.badge.img+3
I’m working on a data inventory project and need to figure out what data sources are being used in a large number of aprx’s. Is there a way to determine the data sources of an ArcGIS project by directing a workbench to an aprx file path?
hkingsbury
Forum|alt.badge.img+73
  • Apr 10, 2025 10:34 PM UTC
Sorry, a very brief reply, but i’ll come back later and expand if needed.
You can use ArcPy in a PythonCaller to list the layers in an APRX
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/updatingandfixingdatasources.htm
https://chatgpt.com/share/67f84756-d79c-8005-ac73-b522691aa5b5
koala_pond_03
Participant
Hey, I’ve made a python script for a similar project at work. I hope this helps.
import csv, arcpy, datetime, time
aprx = arcpy.mp.ArcGISProject(r'\\network\folder\project.aprx')
maps = aprx.listMaps()
for map in maps:
layers = map.listLayers()
out_path = r'\\network\folder'
ts = datetime.datetime.fromtimestamp(time.time()).strftime('%Y%m%d_%H%M%S')
csv_file = out_path + r'\aprx_report_' + ts + '.csv'
print(csv_file)
output = ''
output = 'Layer,Group_Layer,Feature_Class,Server\n'
def listLayers():
results = ''
temp = ''
featureLayer = layer.longName.split('\\')
if len(featureLayer) > 0:
try:
datasource = layer.dataSource
datasourceProperties = datasource.split(',')
d = dict(s.split('=') for s in datasourceProperties)
groupLayer = featureLayer
del groupLayer[-1]
groupLayer = ' >> '.join(groupLayer)
temp = (str(layer.name) + ',' + groupLayer + ',' + d.get('Dataset') + ',' + d.get('Server'))
results = results + temp + '\n'
except:
print('failed: ')
print(featureLayer)
if len(featureLayer) == 0:
try:
temp = (str(layer.name) + ',,' + d.get('Dataset') + ',' + d.get('Server'))
except:
print('failed: ')
print(featureLayer)
return results
def listRasters():
results = ''
temp = ''
try:
## print(datasource)
if len(datasourceProperties) > 1 :
del groupLayer[-1]
temp = (str(layer.name) + ',' + ''.join(groupLayer) + ',' + d.get('Dataset') + ',' + d.get('Server'))
if len(datasourceProperties) == 1:
temp = (str(layer.name) + ',,' + ''.join(datasourceProperties) + ',')
else:
pass
except:
print('failed: ')
print(featureLayer)
try:
pass
# datasource = layer.dataSource
# datasourceProperties = datasource.split(',')
# d = dict(s.split('=') for s in datasourceProperties)
# temp = (str(layer.name) + ',,,')
# results = results + temp + '\n'
except:
print('failed: ')
print(featureLayer)
return results
for layer in layers:
if layer.isGroupLayer == True:
pass
elif layer.isRasterLayer == True:
output = output + listRasters()
elif layer.is3DLayer == True:
output = output + listLayers()
elif layer.isFeatureLayer == True:
else:
pass
print(output)
file = open(csv_file, 'w')
file.write(output)
file.close()
print('done')
creinier
  • Apr 11, 2025 12:11 PM UTC
Thanks ​@hkingsbury and ​@koala_pond_03 for the suggestions and examples! I’ll give that a shot!
